fifesjeep wroteYou can get a set of Universal ACCEL Super Stock 8mm Wires... You should get the ones that need to be cut... this way they'll fit the way that you want them to...
With the boots... I normally use a touch of vasoline on my large needle noses insert in the boot and expand them doing a complete 360... This makes sliding the ends in 20x easier. Don't stretch it to far just enough to give a good push and she's seated properly... You can use the electric compound also... probably prefered..
Just put the ACCEL 8mm on the Heap (RED to match the paint scheme :wink: ) - yea, PITA to get them made using the crimping tool they provide (a vise makes it easy, but I don't have a vise mounted on my Jeep 111!!! ) And keep the moulded sparkplug boot - it's easier to trim and fit the cap side boot. A little silicon on the metal tip and in the cap-boot and push that sucker on there :idea:
And use some 'electronic grease' - silicone (I use CRC brand personally), it's not expensive, it's water proof and keeps the corrosion down. I use it on ALL of my connectors on the Jeep, not just plug wires. If the 'grease' is there, water and gunk don't have a place to accumulate and short out :mrgreen: Vaselene will melt out over time I would think ... :-|
