jharlan68
I have a '75 CJ5 with a 304. I'd like to change the dizzy out, but as most readers, I have very little money to play with. I'm not a hard core trail hound, but I want to upgrade to a more reliable system. I've read both pros and cons about the HEI setups using a Ford 460 and GM and need to know the least expensive and easiest way to do it. Hope I'm not too 111!!!
BREK
Check the store here mc has a nice hei setup for $155.
You can run the larger cap and hotter coil from a Ford 460 this is called the TFI swap. The HEI is a hotter spark and larger cap unit but it eliminates the ignition control module, stock coil and excess wiring form the engine bay. In fact if you dont have a electronic choke or AC you would have 5 wires plus you plug wires when you go to an HEI.
jharlan68
'preciate the advice. Love the forums, you guys rock!! :lo1l: :lo1l:
