For a 401 Crank in a '70 & up 9.208 Deck Height 360 Block,
off the shelf 360 +.030 4.11 bore cast pistons with a 1.581 Comp. Ht.
will work if '68-69 390 5.790 Connecting Rods are used.
If Rods are re-conditioned they get about .003 shorter and become 5.787 c to c.
If off the shelf forged 360 pistons are 1.581 Comp Ht. they'd also work.
Believe the '68-9 390 rods also use the 1.001 Wrist pins though.
Using nominal dimensons this yields 0.000 deck clearance.
Interesting that this ends up being 390 Cubic Inches
Using a 27cc piston dish volume and 4.25 bore x .045 thick head gaskets,
58cc open chamber heads yields about a 9.38:1 Static CR.
54cc Edelbrock Alum. heads yields about 9.75:1 Ststic CR.
51cc closed chamber heads yields about 10.04:1 Static CR.
If more CR and less Piston to head clearance was desired
then the block deck height could be reduced by milling or
the 401 crank could be offset ground by the desired amount.
Forged pistons with a less than 27cc dish volume would also increase CR.
'70 & up...1/2.......'68-9............Aftermarket...Engine
360.........401.......390....Deck...360 Piston.....Cubic
deck ht....Stroke...Rod....Clear...Comp Ht.......Inches
9.208......1.840....5.787..0.000...1.581..........390
Does this sound right, or is there an overlooked error ???
