OK, back on topic ....
Henry Lavrenz wroteWho makes or can make a timing gear cover to work with the Milodon cam gear setup? MC can you do this? I had a oem cover welded up - but the bolt below the weld leaks, really bad. I have my turboed' 401 all apart now and ofcourse the cover/oil pump is one of my concerns. Hankrod
Will your new 2-pices timing cover design acomodate a change to support the Milodon gears and still support stock water pumps? Just a thought if the design could accomodate variations for gear trains and then again if the base could be modified to work with different tops covers for different water pumps :mrgreen: :-|
