melton83 wroteI Well I was forced to have the machine shop fix the problem because I'm just not to that level yet to be able to troubleshoot this kind of thing. ( Plus my wife was getting fed up with only having one car). They did a dye test and found that the cam gear was riding to high and had to be lowered down. Well there are two different holes on the end of my HEI dizzy shaft for mounting the dizzy gear, so they droped it down to the lowest hole, and found it was meshing up where it should be so that fixed that. They put on a MSD gear set. They also were aware of the known AMC oiling problems and drilled a hole that would allow more oil to squirt onto the gears. So far so good. I reaaalllly hope this doesn't happen again!!
I figured as much... As for drilling a hole for extra oiling... I'm not 100% sure if you actually needed that... They did say that you were getting good oil supply already... and that wasn't the issue... :-| Did they disassemble the block before they drilled it? If not you're going to have fine metal shavings getting into everything... Bearing and journal surfaces,oil pump/filter, lifters, pushrods etc... Chances are it'll settle to the bottom but... Even that, I'd have them yank it, clean it and rebuild it for free...
