Dusty
J20 front D44 axle goodies Hi steer
77 J20 WT front D44
Poison spyder hi-steer arms. Poison Spyder 1" spacers. Includes driver side and passenger side knuckles, which are already drilled tapped and studded. and Poison spyder HD Tie-rod with hiems.
Some use good shape $340 for the whole bag knuckles and all
Jeep / Chevy D44 8 lug spindles rotors and backing plates $50
D & P side
Some use, Superior Alloy inner alxe shafts & 1 Warn Stub, 1 stock stub No joints $225
Front axle housing setup for Spring over. Free come get before i dump
If you want the whole housing with the shafts ect and you are local, $500 for the whole sheery. There is no ring and pinion and no carrier in this housing
Dodge 1/2 ton D44 knuckles, spindles, backing plates, rotors and hubs, axle stubs ......no locking hubs though but everything else to convert what ever you have to 5 on 5.5 bolt pattern llike maybe a jeep cj or Waggy. FYI if you have a d30 you will need to upgrade to shafts that take 297x or 760x joints since dana 44 shafts run the bigger joint. BTW these are Flat top knuckles driver and passenger. $140 for the set
Im pulling it apart this weekend.
located 95404
Shipping on your Dime
willing to consider other options with breaking it up
Thanks
DD
