happyhoppy
Might be a simple answer to this......
Have a used Edelbrock Performer Intake I want to install on either my AMC 360 with a 2bbl Motorcraft or an AMC 401 with a Mcraft 4300 4 bbl.
Missing the oil splash pan on the bottom of the Edelbrock - is there a difference between the 4 bbl and 2 bbl splash pans?
I have an extra 2bbl intake - hate to install the splash pan on the Edelbrock and find it won't work on the 4 bbl when I install it..... Thanks
All the splash pans are pretty much the same. There is a difference in shape and placement of 1 of the rivet holes, but I'm not sure what year they changed. Even those will swap if you re-drill the one hole in the correct place, or just leave the rivet out.
