I have a dilema with my rig. It's strictly a rockcrawler, FYI. It runs on propane. It will also be getting a fresh TJ999 to replace the current one.
I have a tired 360 with an Edelbrock intake and cam. It has good low end grunt, and I can't complain. The problem is the heads are worthless, as well as the exhaust manifolds. Someone welded the exhaust directly to the manifolds. 111!!!
The engine burns a ton of oil due to bad valve seals. It's 1973 vintage.
I have an 86 360 in my posession. It ran like a top when it was still in the Waggy. I had oringinally planned to swap the heads and exhaust manifolds, but that is going to be a lot of work. I plan to remove all the emissions garbage and stick with my propane and Edelbrock intake. How much low end am I going to realistically miss with that cam? It will save me a ton of time, $, and headaches to just swap the engine/tranny at the same time.
I also plan to put a 4:1 in the t-case, so I should be helping the motor a bit there as well.
