tufcj wroteScout T-18 won't work unless you transfer the internals to a Jeep or Ford case, or adapt the Scout bellhousing. On a Scout (unless it's AMC powered), the T-18 case is unique, bolted on from inside the bellhousing.
That's incorrect. You change the input shaft - have it matched to a T-150 and change the input bearing retainer. We used to have a good writeup with pics on our local board. It wasn't very expensive to do, either. The difference in the bellhousing attachment is negligible. Set it up with bolts, studs, through bolts, whatever you want.
