I dont know anything bout benefits of kerosene. I know stacey david from trucks covered everything you need to do in starting and preparing a engine thats been sitting for a while, hes got his show called gearz and his website www.staceydavid.com maybe you can find an old episode there or check out their forum. If it was me doing this, i'd drain old fluids. lube cylinders with a lil oil via spark plug holes, fill with your normal 5 quarts of oil, 1 quart lucas oil stabilizer, or whatever spec you want, turn over by hand, replace spark plugs, cap, oil filter, rebuild carburetor (old gas turns into white dust looking stuff from sitting, replace fuel, fuel filter, clean out gas tank if using the same one, new battery. Check hoses, belt have basic gauges hooked up so you know oil press, temp.
