sac_waggon
So I have a 75 Wagoneer with an AMC 401 in it. There has been a tapping sound comming from the top of the enging ever since I got it. I pulled the valve covers to check for any loose rockers when I found the strange bridged rocker setup. Making sure each valve was closed, I went down each head and torqued the rockers to the proper spec, but none were loose. Then I noticed some side to side play between the rockers and the little pad thing that the rocker bridge sits on. It is this side to side play that I believe is making the noise. Is the side to side play normal?? Will it hurt anything??? It sounds kinda scarry, but it seems to run alright and has not gotten any worse since I bought the vehicle almost two years ago. Will a new set of rockers and new rocker bridge kit solve my noise problems, or is this just how these bridged rockers are???
TIA.
Mike
