To help dummies like me .... an on-line Calculator
Or simply, a 360 that's .030 over needs, with NO OTHER MODS, 581 CFM with a 100% VE (volumetric efficiency) and a top end of 5500 rpm. But who's perfect? At 90% VE that same engine only needs 465 CFM, or with MCs math - it works out to 605 CFM. :-|
So the lesson for today class, polish ur heads, clean-up the intake and exhaust flow paths, go bigger on the bump-stick and let that puppy breathe!!
VE = Volumetric efficiency in internal combustion engine design refers to the efficiency with which the engine can move the charge into and out of the cylinders. More correctly, volumetric efficiency is a ratio (or percentage) of what volume of fuel and air actually enters the cylinder during induction to the actual capacity of the cylinder under static conditions. Therefore, those engines that can create higher induction manifold pressures - above ambient - will have efficiencies greater than 100% (blowers, etc...). Volumetric efficiencies can be improved in a number of ways, but most notably the size of the valve openings compared to the volume of the cylinder and streamlining the ports. Engines with higher volumetric efficiency will generally be able to run at higher RPM and produce more overall power due to less parasitic power loss moving air in and out of the engine.
-Wikipedia®
