73hornut wroteStarter relay is bad.
???? Starter kick's in and runs fine ??? Starter Solenoid maybe?? That's what I'm about to swap out with my trail spare (thought I'd check in here first) after I check the wiring from the IGN SW. (it was smoking the other night while trying to start this b/tch. Don't know if it was really the relay or the rubber on the cables - they were pretty danged hot!!
74on35s wroteI'm not familiar with your build so forgive the q's. Not a problem, thanks for your time
What ignition system do you have? Stock or some aftermarket type ignition control box? How is it wired for power?
If you don't have a resistor wire (or ballast resistor) on a stock type ignition system and coil, that might be your problem.
I put a Jacobs coil on mine when it started acting up, wired thru the purple wire on the dizzy. didn't help a bit. Ended up wiring a new wire from the switch (after replacing the switch and the soliniod to no avail) directly to the coil. tested it about 10 miles from the house and it ran great! for about 30 minutes...then it died, and we ended up towing it home...
Turned out even some of the aftermarket stuff needs that resistor wire or a ballast resistor :oops: :oops:. I ended junking my pertronics points eliminator and the Jacobs coil. Now its got a new electronic dizzy and a TFI conversioin. just waiting on the control box (or chevy HEI module) to finish it up.
360, .030 over, balanced, crank has been cross drilled, turned and polished, Summit 8600 cam, Performer intake with E-Brock carb (w/off road needles/float). Painful harness (no computer) and rebuilt Stock dizzy but TFI coil, new plugs & wires, front end is the Bulltear Timing cover & oil pump :mrgreen: with new cam and dizzy gears (and the wear pattern looks god so far :t: ) Been thinking on the HEI outta MC's store here, but just threw $3500 at the man-childs truck (new tranny and wiring problems - a dozen melted wires hidden in the harness) so the new sparker will have to wait.
Like I mentioned, it ran for break-in then I 'went away' for about 7 months. (sounds a lot like your "30 minutes" :-| ) Now I'm trying to get rolling so I can get the exhaust done.
Tried the Jacobs on the Chebby 2500 and had to take it off when the coil melted :shock: Most of it is in a box occupying space in my shop :oops:
