HI all!
I've got a transplanted 360 in my '74 CJ-5, and I want to install an OBA system on the CJ, but I can't find the right crank pulley (or the upper mount for the compressor) anywhere.
I've kinda narrowed the year down to a 1970 or so, but thats not for certain.
My question is, what years used a 3 bolt pulley on the harmonic balancer? Most of the 360's I've seen have a 4 bolt pulley.
My 3 bolt pulley has a smaller center hole than the 4 bolt ones I've seen, also.
If it helps, near as I can tell my engine casting (on the rear of the engine) is 6195528, but I cant find that in any lists, so maybe its 3195528 (360, '70-'84)
Dizzy takes the same (dwell type) points as a '70 matador...not a CJ type points set (2 trips to the parts store, second one with the dizzy in hand!) :?:
