JERSEYJOE
I am going to plump my remote filter and cooloer with either Russell's or Earl's lines. What is the correct size to use? I am thinking -8.
-10 is what I would recommed for your setup there Joe. -10 are 1/2-npt. You could go -12 with a 1/2-npt but they are more expensive.
JERSEYJOE
Thanks MC. Is there an updated pump cover or should I use the one I bought from you a year or so ago? I think the number 626 is stamped in it with some letters.
If you bought a oil filter relocation plate the only difference would be the lettering. No need to buy something else. :idea:
JERSEYJOE
MC: I sent in an order the other day and I think I ordered oil pump gears because I thought there was an update. The cover I have I bought a couple of years ago. It's nickel, also got the midplate, remote filter housing and the pump cover with the threaded ooenings. I also came up with an interesting way to mount an oil cooler in a CJ. I'll send pic's when I put it together.
