XJ-001
All,
I'm looking for the front axle shafts for a 1982 J10. Also looking a rear driveshaft for the same. V-8, 727, long wheel base (131")
Thanks,
Tom
JERSEYJOE
If you collapse the yoke, what is the total length? I have a bunch from various Jeeps.
XJ-001
I wish I knew, as the driveshaft wasn't there. We're converting the truck, which was a 6 cyl/3spd to a 360/auto. I do know it's one of the 4" diameter shafts that the LWB trucks used.
JERSEYJOE
Yes I have about 6 of these 4 inch diameter shafts. measure from the u joint cap center to center at running ride height.
KEV
If you need the length yet I have a 82 J20 at the shop in St Paul with a 360/727/208 but it does have a 60 in the rear vs your 20. I might have a spare set of front shafts too.
call me 651-644-2323
ask for Kevin
mrtazwrench
may have some of that here in my pile of J-trucks.
XJ-001
I went to Kaj's yesterday to work on the truck, and measured the yoke distance. They measure 60" center-to-center. of course I have one shaft that's 55" and one that's 65". Still looking for front axle shafts.
mrtazwrench, I tried the link,but server was not found.
JERSEYJOE
Just so we understand, with the slip joint compressed the distance from the u joint center cap center to cneter is 60 inches?
XJ-001
It's 60" between the TC yoke and the rear end yoke. The drive shafts I have, when the slip yoke is extended about 60%, one is 55" and the other is 65". I may just take the longer one and have it shortened.
XJ-001
Still looking for front axle shafts for this truck. We had a rear driveshaft made.
Driver's side shaft is 27.6" OAL
Passenger side is 44" OAL
Does not have the vacuum disconnect axle
The following vehicles use the same axles:
1980-1983 Cherokee Chief (wide-track)
1980-1986 J10/ J20
1974-1979 axles and Wagoneer axles won't work.
Thanks,
Tom
