ironman_gq wroteyou may want bigger injectors if this motor is going to breathe really well. I think that even on the 350's they can start to run lean with performance mods.
True. If you start modding, you'll want bigger injectors. But for a mostly stock 360 with stock air cleaner, stock exhaust and stock cam the 350 injectors are adequate. You may end up leaning out at high RPMs but if you're not pushing your engine (such as daily driving a 77 Cherokee and not wrapping out the motor past 4K basically ever) the stock 350 setup is workable.
