I bought the complete Howell system about 5 years ago for $1250 to my door. It came with everything except air cleaner, fuel line, and a bracket to hold the ECM. It included a rebuilt TB, new MAP, water temp, and O2 sensor w/bung (this does need to be welded in), used GM ECU with a PROM custom burned for my cam/exhaust combo and a plug and play wiring harness. You just need to supply power/ground, and a wire to the fuel pump. They say you can use the factory fuel lines, but suggest you use bigger feed/return for best performance.
I installed it, including new fuel lines, in under 8 hours. The harness was well marked, and instructions were good. It fired first try, and aside from 2 bad O2 sensors, it's been flawless.
Howell will sell you whatever components you want, but I decided to buy the full kit just so there was no "finger pointing" in case it didn't work right.
www.howell-efi.com
