rollbar
This might be first grade but below is the list of trannys for Peaches '86 CJ7. I know the list says the 177/178 R for trucks but I have a question.
Peaches tranny ('86 CJ7, 258, 4sp, D-300, D-30/44, 3.31 gears factory) is not aluminum, it is cast iron & I was just sitting here thinking about it & all these web site saying the CJ has the aluminum tranny. Hummm, now the CJ8 I got (in pieces) has the aluminum tranny. Can someone explain this? I was told her Jeep was ordered w/a tow package but ???
Thanks,
Rollbar
P.S. I am also getting some conflicting reports about putting this tranny behind a 360 & people saying it will hold up just fine but then again, I was told it wouldn't. HUmmm, ???
The T-176, T-177, and T-178 are medium duty Ford transmissions manufactured by Tremec in Mexico. They have an aluminum case with the casting number 2604203. This transmissions has a 1 1/8" 10 spline input shaft and a 23 spine output shaft. These transmissions are very similar except for gear ratios. These transmissions use the standar bolt pattern used by Ford transmissions.
Usage:
The T-176 was used in CJs from 1980-1986 and other Jeep trucks from 1980-1987. The T-177 and T-178 were not used in CJs, only in other Jeep trucks.
Transmission 1st 2nd 3rd 4th 5thRev
T-176 3.52 2.27 1.46 1.00 3.52
T-177 3.82 2.29 1.46 1.00 3.82
T-178 3.00 2.08 1.47 1.00 3.01
Rhinolined360
I havent had a problem with my t176, I am more concerned with m20 axles
rollbar
Thanks, but why would she have a cast iron tranny & all the rest of them are aluminum. Almost everyone I talk to has the aluminum tranny.
hugh
The only factory iron 4 speeds offered in a jeep are the T18 and T18 A. The T 18 was offered in CJ,s until 79 but also was offered in J trucks until 85. It has a casting no of T18 or 1301 on the side and is a great gearbox with a 4.03 first gear. The T18 is similar with a 6.32 first. They are both keepers. Given the fact that the factory was prone to using old stock and that there were options available coupled with a lot of Jeep owners tending to swap and modify their rides, the orig tranny may have been swapped out. A friend of mine works at a local jeep rebuilding place and he says even the 97 TJ,s are a mix or older {YJ} and newer parts.
rollbar
Thanks, I'll look for the numbers to night & post. I did replace the clutch once & I'm telling U it's cast. I bought the Jeep long, long ago w/50K on it & he was the second owner & kept it in the garage & did not wheel it. The first owner sold it right after he got it so everything seems to add up & all the factory stuff jives. If it is the T-18 I'll have to swap my aluminum one out for Peaches cast iron one for the 360 :shock: , don't tell Peach :? :shock: :?:
The T-176/Dana 300 was first offered in 1980. The T-18/Model 20 was 79 and older. My memory is that the T-176 is a cast iron tranny, and was only offered for a couple of years. The later T-4 (4 speed) and T-5 (5 speed) were aluminum cased trannies.
rollbar
Thanks Bob, I'm gonna look tonight when Peach gets home, if I can see w/all the mud shes been in :smile: :mrgreen: . I'll let U know.
Jim its hard to say if someone didnt swap in a T18. Does your T-case have a rear housing made out of steel (Dana 20) or aluminum (Dana 300). I have also seen t19 trannies from scouts with texas pattern 1980 Dana 300 from a scout swapped in (now that took a little while to figure out when I saw it)
rollbar
MC- the D-300 on her Jeep is cast iron, I mean the whole thing is bullet proof (so to speak) & all the other Jeeps I look @ are aluminum. Now I'm not complaining, I'm just kind of pissed :? #-o cause I've said many times to Peach, I'm gonna swap your stuff out into mine, she said :(: :bazooka: :bs: . I guess I taught her to much about Jeeps :downtown: ](*,)
rollbar
When I bought the Jeep I asked the owner if anything had ben done to it, he replied no (he was older in his years) & said the original owner did nothing to it as he didn't have it that long. It was a trailer/garage queen, but not anymore :mrgreen: .
rollbar
MC-rear housing meaning the tail shaft? If so I think it's aluminum (I would have to double check tonight) cause every D-300 I have seen is cast iron.
Rollbar the Dana 300 has a aluminum tailshaft and the Dana 20 has a cast steel tailshaft. Paint and dirt can hide the material pretty well.
rollbar
I almost 100% sure it's a D-300. 4L, 2wd, N, 4H on the shifter & it looks exactly like one. I must be loosing my mind after all these years. Pics tonight but Peach just called & said she went wheeling this morning B-4 work 111!!! .
P.S. I had that backwards, the D-300 has the alum tail & the D-20 cast. Told U I was loosing it.
rollbar
rollbar wroteMC-rear housing meaning the tail shaft? If so I think it's aluminum (I would have to double check tonight) cause every D-300 I have seen is cast iron.
I meant the housing is cast, sorry, I didn't explain it right.
rollbar
I'll post some pics tonight as well as some numbers of the tranny. Like I said in my first post, back to first grade of Jeeps :shock: 111!!! #-o
rollbar
Well it seems like I need to go to the funny farm or I was thinking of another tranny. Sorry to put U through this (moderator, delete if U want to) but it seems from getting some of the brown mud off the tranny is aluminum so it must be a T-4. Below are the T-case numbers & tranny numbers. Wow, did I have a memory lapse. 111!!! I'm embarrassed #-o , oh well :shock: :?
T-case-C-300-15-2 BW 2405
309007-4
5364854
S/N-384138
Tranny-RGKF23
1086
5359389
rollbar
So I went here & it only shows the 176 4spd for that yr. but it's an aluminum housing.
http://jeep.off-road.com/jeep/article/articleDetail.jsp?id=277032
hugh
If its a T4 it should have the no 13 -51 cast into it somewhere. Its supposed to be a weak trans and best swapped out.
rollbar
IT has some numbers cast in the front where the bell housing bolts to. I seen the number 23 & some others but couldn't make them out. I need younger eyes :shock: . I'll see if I can get them.
rollbar
Nope it's a 176, looks like this. Plus I have two. :?
http://www.novak-adapt.com/knowledge/t176.htm
Thanks, I must be loosing my mind 111!!! but U all helped me find it. :mrgreen: :t:
