khotmer okayi have an 1982 wagoneer with a 360. I know i have a vacume leak and I need to rebuild my carb (2150?) there is a connection from the carb to the intake on the pass side with 2 metal lines running to the back of the carb around the choke. what is it? where can i get a replacement? mine rusted and broke when i removed the carb
AMX69PHATTY That is the Choke Stove, sealed tube goes into a cavity under the intake that has exhaust gases passing through it to heat the air that goes through the tube and opens the choke. Pretty sure those parts are available somewhere.
