OK, best guess from whoever wants to take a shot at this.
I have an intermitant dead cylinder. It fires probably every 2nd or 3rd cycle.
I swapped plugs and wires around (and then wires and plugs), and it's only showing up on the same cylinder....every time.
Everytime i pull a plug on that cylinder it has fresh oil on it, the rest look great.
I havent done a compression test on it yet, but can someone give me an "educated guess" as to whether this is most likely a bad set of rings or a valve issue (keeping in mind the intermitant miss and the oil) The fact it's not missing every time tells me i probably dont have a burnt valve or a hole in the piston...but that's as far as im willing to guess.
the miss started up rather randomly, and only occasionally, but now it's all the time.
Will a compression test diagnose the difference between bad valves and bad rings?
