Fuzz had some pics on the post "Alternator Mount Pics Needed" on page 2 of this forum, but now they are red x's. He moved some folders around he said, but maybe he'll repost them. Let me try to describe it though.
The highest hole in the "window bracket" bolts thru a lock washer, thru the York mount, and into the head.
The bolt furthest right (closest to the window) in the "window bracket" goes thru a lock washer, thru the bracket, thru a spacer, thru the water pump, thru the timing cover, and into the block.
The hole furthest to the left in the "window bracket" gets either a 7/16-14 x 6 1/2" long bolt or a 3/8-16 x 6 1/2" long bolt, depending on what your head takes. Be careful, a 3/8 screws right into the 7/16 hole, but just won't tighten. Also, make sure the 7/16 fits thru all the brackets and alternator. We had to drill ours out. They made 2 versions of the alternator mount, a 3/8, and a 7/16. The bolt goes thru a lock washer, thru the "window bracket", thru the alternator, thru a short brace the other end of which bolts to the head (or water pump, or block, don't remember) thru a 3 1/2" long spacer, thru a 6 1/4" long brace, then finally into the head.
The other end of the 6 1/4" long brace bolts to a boss on the backside of the alternator.
Probably the biggest trick is tightening the engine end of the short brace immediately behind the alternator on the bolt the alternator swings on. You can't get at it with the "window bracket" in place. What we did was run the 7/16" bolt thru this short brace, the spacer, and the long brace, and into the head. That positioned that end of the short brace. At that point we tightened the bolt in the engine end (with the "window bracket" off). Then, you can carefully remove the long 7/16" bolt, and that short brace will keep the spacer and long brace pinched in place while you put the alternator and "window bracket" on. A couple less things to have to try to hold.
This alternator mount is a Rube Goldberg, and a real pain to figure out, especially since there were several different setups, but, when it's all together, it's real secure.
I'd REALLY recommend putting the alternator on the engine BEFORE you drop it in the vehicle. It's a lot easier to get at everything.
PS-we didn't have the long spacer either, so I just cut a piece of 1/2" pipe to the right length and used that.
Whew, after all that I find a drawing. What do they say about a picture?
