JERSEYJOE
Anyone running Hummer H2 wheels on their Jeep? I am using a Dodge axles with 8 lug. The threads are 9/16 18. The Hummer H2 came with metric M14- 1.5 studs. Short of changing all the studs and using the stock H2 lug nuts I was wondering which OEM style 9/16 lug would work.
Anyone??????????
dan58
I'm running beadlocked H2s on my D60s. Not a problem. Just be sure the studs are long enough.
1980_Cj7
We're running H1, 2 piece, 12 bolt double beadlocks (8 lugs). We simply found lug nuts that fit the studs on our drums/rotors, and made sure the cones fit the holes in the wheels. We actually have two different size lug nuts, one to fit the Chevy Dana 60 front axle, and another to fit the Ford Dana 60 rear axle.
Works great. So far the wheels have only fallen off 3 times. Not bad. :wink:
I ran a set of H2s I really didn tlike the 7" of backspacing on the particular appplication but I would like to run them again on my Mogs.
JERSEYJOE
Matt: which lug nuts are you running?
They were std shorty lugs that I ran in twice with a air wrench. They held tight and wheeled well. I picked up my set for $230 shipped off ebay a while back.
