ironman_gq wrotedoes it run good or does it seem like its low on power? Had a similar problem but mine sounded like a gremlin with a hammer beating on my engine. turned out to be a broked pushrod. I still had oil pressure and for some reason it wouldn't start making noise until it had warmed up significantly.
was it the intake or exhaust?
im curious what would happen if you broke an exhaust pushrod. Where the hell would the expanded gasses go after ignition? Im thinking that would break something in a bad way when the exhaust stroke of the piston tried to compress the already expanded gasses...being the exhaust valve would be stuck shut.
