frenchy wroteJust installed a new sending unit in '75 CJ5.
Was hoping to clean up some of the plumbing, just want to make sure this is going to work before I put the body back on it...
2 Fuel lines come out of the side of the tank, to/from rollover check valve and/or carbon cannister?
Can I plug them up?
not a good idea.
frenchy wroteSending unit has 2 lines as well, I have new lines to run to the carb, the 2nd line I'm guessing is return line from carbon cannister?
vapor line from the tank. part of the evap system.
frenchy wroteCan I plug it?.
not a good idea.
frenchy wroteShould I leave one open as a breather and put some type of 1 way valve on?
imho, run new fuel and vac. lines. if you have a manual, the diagrams will be in there. if you don't get one.
frenchy wroteWill I be getting enough fuel to run a Holley Truck avenger 4Brl (670CFM) sitting on an Edelbrock Performer(non egr) intake? (AMC 360)
Holley says the recommended fuel pressure is 5-7 psi.
3/8" should be fine.
np. the evap system is there to allow the fuel vapors to be burned in the engine and not be released into the atomsphere. also it helps keep the fuel in the tank instead of evaporating with the engine off. a 75 has a pretty simple system, there's not really much to clean up. just replace the old lines.
