82Waggy wroteI had a brand new one that was stuck due to casting debris and machining flash.
Make sure the plunger drops all the way in so that the point on the end touches the far wall, and that it is free to move easily back and forth without the spring. If it won't bottom and fall out freely without the spring you need to ream out the plunger cavity to the proper diameter and get rid of all the garbage.
so what you are saying is that the plunger should slide in and out easy, I get that part
If I am under my Jeep and slide the plunger up in the hole it should freely fall back out?
If that is the case, the plunger I have fits real tight and will not come out on it's own, when I push it up in there, with or without the spring it stays and does not come out on it's own
