killahxft_jeep
I'm trying to figure out exactly what year, and what type heads this engine has.. it's a 360 as per the "360" in the casting between the two casting plugs on both sides..
on the rear drivers side near the top bellhousing bolt is:
3195528X (web) 2 (web) H
on the heads is:
3233344
in the intake valley is:
360 237 86 2
and all over are small cast tags that say 86 on the heads and block, does this mean my block is an 86? or am I fooling myself that it's that simple? I know the engine is out of a grand wagoneer.. just want to find out the specifics on this particular engine.. I know waggys were built from 63 to 91..
also on the first counterwieght lobe of the crank (closest the timing cover) there is a space that has been de-burred and a tag is stamped on the lobe.. I'll have to get the numbers/letters off tha later, could this engine have been rebuilt? what numbers should I look for on there? I ask because although this engine was said to be a DD.. there is next to NO wear on the piston skirts & cylinder walls...
The last 1 or 2 digits of the year are SOMETIMES cast in the lifter valley and heads. You're probably correct that you have an 86 block and heads. The 528 block casting was 360/401 from 70-up. The 344 heads are standard 79-up bridged rocker heads.
I think 86 was the first year that the blocks had freeze plugs in the rear, under the flywheel/flexplate.
