Cant remember the site this was off of.
Engine |engine|chassis|
Year Engine Carb Bore
and
Stroke Piston
Dis
place
ment
Cubic
Inches Com
pres
sion
Ratio
(Stan
dard) Maximum
Brake
H.P.
R.P.M. Maximum
Torque
Lbs. Ft.
R.P.M. Normal
Oil
Press
Lbs Spark
Plug
Type Spark
Plug
Gap Point
Gap Dwell
Angle Firing
Order Ignition
Timing
BTDC
or
Mark Grnd
Volts
1960 90 H.P. American 6-196 1 Barrel 3.125 x 4.25 196 8.00 90 @ 3800 150 @ 1600 50 AL-7 .035 .020 37-41 153624 3¬? -12
125 H.P. American Custom 6-196 1 Barrel 3.125 x 4.25 196 8.70 125 @ 4200 180 @ 1600 50 ARL82 .035 .016 28-35 153624 8¬?/10¬? auto -12
127 H.P. Classic 6-196 1 Barrel 3.125 x 4.25 196 8.70 127 @ 4200 180 @ 1600 50 ARL82 .035 .016 28-35 153624 5¬? -12
138 H.P. Classic 6-196 2 Barrel 3.125 x 4.25 196 8.70 138 @ 4500 185 @ 1800 50 ARL82 .035 .016 28-35 153624 5¬? -12
200 H.P. Rebel V8-250 2 Barrel 3.5 x 3.25 250 8.70 200 @ 4900 245 @ 2500 55 ARL82 .035 .016 28-32 18436572 TDC -12
215 H.P. Rebel V8-250 4 Barrel 3.5 x 3.25 250 8.70 215 @ 4900 260 @ 2500 55 ARL82 .035 .016 28-32 18436572 TDC -12
250 H.P. Ambassador V8-327 2 Barrel 4.0 x 3.25 327 8.70 250 @ 4700 340 @ 2600 55 ARL82 .035 .016 28-32 18436572 TDC -12
270 H.P. Ambassador V8-327 4 Barrel 4.0 x 3.25 327 9.70 270 @ 4700 360 @ 2600 55 ARL82 .035 .016 28-32 18436572 5¬? -12
55 H.P. Metropolitan 4-91 1 Barrel 2.875 x 3.50 90.9 8.3 55 @ 4600 82 @ 2400 50 AL-7 .024 .015 35-41 1342 7¬? -12
1961 90 H.P. American 6-196 1 Barrel 3.125 x 4.25 196 8.00 90 @ 3800 150 @ 1600 50 AL-7 .035 .020 37-41 153624 3¬? -12
200 H.P. Rebel V8-250 2 Barrel 3.5 x 3.25 250 8.70 200 @ 4900 245 @ 2500 55 ARL82 .035 .016 28-32 18436572 TDC/8¬? auto -12
215 H.P. Rebel V8-250 4 Barrel 3.5 x 3.25 250 8.70 215 @ 4900 260 @ 2500 55 ARL82 .035 .016 28-32 18436572 TDC/8¬? auto -12
250 H.P. Ambassador V8-327 2 Barrel 4.0 x 3.25 327 8.70 250 @ 4700 340 @ 2600 55 ARL82 .035 .016 28-32 18436572 5¬? -12
1962 90 H.P. American 6-196 1 Barrel 3.125 x 4.25 196 8.00 90 @ 3800 150 @ 1600 50 H10 .035 .020 37-41 153624 3¬? -12
125 H.P. American Custom 6-196 1 Barrel 3.125 x 4.25 196 8.70 125 @ 4200 180 @ 1600 50 H18Y .035 .016 28-35 153624 8¬?/10¬? auto -12
127 H.P. Classic 6-196 1 Barrel 3.125 x 4.25 196 8.70 127 @ 4200 180 @ 1600 50 H18Y .035 .016 28-35 153624 5¬? -12
138 H.P. Classic 6-196 2 Barrel 3.125 x 4.25 196 8.70 138 @ 4500 185 @ 1800 50 H18Y .035 .016 28-35 153624 5¬? -12
250 H.P. Ambassador V8-327 2 Barrel 4.0 x 3.25 327 8.70 250 @ 4700 340 @ 2600 55 H18Y .035 .020 28-32 18436572 TDC/5¬? auto -12
270 H.P. Ambassador V8-327 4 Barrel 4.0 x 3.25 327 9.70 270 @ 4700 360 @ 2600 55 H18Y .035 .020 28-32 18436572 TDC/5¬? auto -12
1963 90 H.P. American 6-196 1 Barrel 3.125 x 4.25 196 8.00 90 @ 3800 150 @ 1600 50 H10 .035 .016 31-34 153624 3¬? -12
250 H.P. Ambassador V8-287 2 Barrel 3.75 x 3.25 287 8.70 198 @ 4700 280 @ 2600 50 H18Y .035 .020 28-32 18436572 TDC/5¬? auto -12
1964 90 H.P. American 6-196 1 Barrel 3.125 x 4.25 196 8.00 90 @ 3800 150 @ 1600 50 H10 .035 .016 31-34 153624 3¬? -12
198 H.P. Ambassador V8-287 2 Barrel 3.75 x 3.25 287 8.70 198 @ 4700 280 @ 2600 50 H18Y .035 .020 28-32 18436572 TDC/5¬? auto -12
1965 90 H.P. 6-196 1 Barrel 3.125 x 4.25 196 8.0 90 @ 3800 150 @ 1600 50 H10 .035 .016 31-34 153624 3¬? -12
125 H.P. 6-196 1 Barrel 3.125 x 4.25 196 8.7 125 @ 4200 180 @ 1600 50 H18Y .035 .016 28-35 153624 8¬?/10¬? auto -12
128 H.P. 6-199 1 Barrel 3.75 x 3.00 199 8.5 128 @ 4400 180 @ 1600 50 N14Y .035 .016 28-35 153624 5¬? -12
145 H.P. 6-232 1 Barrel 3.75 x 3.50 232 8.5 145 @ 4300 215 @ 1600 50 N14Y .035 .016 28-35 153624 5¬? -12
155 H.P. 6-232 2 Barrel 3.75 x 3.50 232 8.5 155 @ 4400 222 @ 1600 50 N14Y .035 .016 28-35 153624 5¬? -12
198 H.P. V8-287 2 Barrel 3.75 x 3.25 287 8.7 198 @ 4700 280 @ 2600 50 H14Y .035 .020 28-32 18436572 5¬? -12
270 H.P. V8-327 4 Barrel 4.0 x 3.25 327 9.7 270 @ 4700 360 @ 2600 55 H14Y .035 .020 28-32 18436572 5¬? -12
1966 128 H.P. 6-199 1 Barrel 3.75 x 3.00 199 8.5 128 @ 4400 180 @ 1600 50 N14Y .035 .016 28-35 153624 10¬? / TDC Calif -12
145 H.P. 6-232 1 Barrel 3.75 x 3.50 232 8.5 145 @ 4300 215 @ 1600 50 N14Y .035 .016 28-35 153624 5¬? / TDC Calif -12
155 H.P. 6-232 2 Barrel 3.75 x 3.50 232 8.5 155 @ 4400 222 @ 1600 50 N14Y .035 .016 28-35 153624 5¬? / TDC Calif -12
198 H.P. V8-287 2 Barrel 3.75 x 3.25 287 8.7 198 @ 4700 280 @ 2600 50 H14Y .035 .020 28-32 18436572 5¬? / TDC Calif -12
200 H.P. (Late 1966) V8-290 2 Barrel 3.75 x 3.28 290 9.0 200 @ 4600 285 @ 2800 50 N12Y .035 .020 29-31 18436572 TDC -12
225 H.P. (Late 1966) V8-290 4 Barrel 3.75 x 3.28 290 10.0 225 @ 4700 300 @ 3200 50 N12Y .035 .020 29-31 18436572 TDC -12
250 H.P. V8-327 2 Barrel 4.0 x 3.25 327 8.7 250 @ 4700 340 @ 2600 55 H14Y .035 .020 28-32 18436572 5¬? / TDC Calif -12
270 H.P. V8-327 4 Barrel 4.0 x 3.25 327 9.7 270 @ 4700 360 @ 2600 55 H14Y .035 .020 28-32 18436572 5¬? / TDC Calif -12
1967 128 H.P. 6-199 1 Barrel 3.75 x 3.00 199 8.5 128 @ 4400 182 @ 1600 75 N14Y .035 .016 31-34 153624 3¬? / TDC Calif -12
145 H.P. 6-232 1 Barrel 3.75 x 3.50 232 8.5 145 @ 4300 215 @ 1600 75 N14Y .035 .016 31-34 153624 5¬? / TDC Calif -12
155 H.P. 6-232 2 Barrel 3.75 x 3.50 232 8.5 155 @ 4400 222 @ 1600 75 N14Y .035 .016 31-34 153624 5¬? / TDC Calif -12
200 H.P. V8-290 2 Barrel 3.75 x 3.28 290 9.0 200 @ 4600 285 @ 2800 75 N12Y .035 .016 29-31 18436572 TDC -12
225 H.P. V8-290 4 Barrel 3.75 x 3.28 290 10.0 225 @ 4700 300 @ 3200 75 N12Y .035 .016 29-31 18436572 TDC -12
280 H.P. V8-343 4 Barrel 4.08 x 3.28 343 10.2 280 @ 4800 365 @ 3000 75 N12Y .035 .016 29-31 18436572 TDC -12
1968 128 H.P. 6-199 1 Barrel 3.75 x 3.00 199 8.5 128 @ 4400 182 @ 1600 75 N14Y .035 .016 31-34 153624 TDC/3¬? auto -12
145 H.P. 6-232 1 Barrel 3.75 x 3.50 232 8.5 145 @ 4300 215 @ 1600 75 N14Y .035 .016 31-34 153624 TDC/3¬? auto -12
155 H.P. 6-232 2 Barrel 3.75 x 3.50 232 8.5 155 @ 4400 222 @ 1600 75 N14Y .035 .016 31-34 153624 TDC/3¬? auto -12
235 H.P. V8-343 2 Barrel 4.08 x 3.28 343 9.0 235 @ 4400 345 @ 2600 75 N12Y .035 .016 29-31 18436572 TDC -12
315 H.P. V8-390 4 Barrel 4.165 x 3.574 390 10.2 315 @ 4600 425 @ 3200 75 N12Y .035 .016 29-31 18436572 TDC -12
1969 128 H.P. 6-199 1 Barrel 3.75 x 3.00 199 8.5 128 @ 4400 182 @ 1600 75 N14Y .035 .016 31-34 153624 TDC/3¬? auto -12
