AMX69PHATTY
You'll need some '68-9 390 5.790 Rods to get 0.000 deck clearance
with 1.580 compression height pistons.
If ARP rod bolts are fitted rods will shorten by about .003 to 5.787 ctr to ctr.
Don't know if the 360 block will require notching or not :-|
Don't mill the block deck cause deck clearance will be close,
unless you get custom forged pistons made to your own spec.,
get custom length rods, or offset grind to destroke the crank.
360 .030 over at 4.11 bore with 3.68 stroke yields 390 cubic inches.
Ain't that cool :t:
