a440plus6 wrote82Waggy wroteDeep sump pan and pickup tube is all that you need.
Just say no to the valley bypass line.
Why No?
Jerry
I don't think it does anything.
The so called lifter bypass is a line hooked to opposite ends of the passenger side lifter gallery. It can add nothing to flow since pressure is the same at both ends.
Consider that flow through the main bearings is governed by close tolerances. The lifter gallery that feeds the main bearing feed paths is already large enough to out flow them.
The way to increase flow through the main bearings is to either increase their clearances or increase system pressure. Simply increasing the volume of the paths ahead of the bearings by adding the bypass line will do nothing for flow through the bearings.
Some think that if the bearings become worn (increased clearances) that the bypass line can help flow the additional oil needed, but pressure will have dropped system wide, including through the bypass line - time to replace bearings.
IMO the bypass line is some shade tree mechanics idea of a fix to a problem he did not understand. What is needed is a properly functioning oil pump and a well maintained engine.
