gschuld
Does anyone make c-clip eliminators for model 20 axles? I'm looking to run moser axles soon and this would be the time.
Thanks,
George
runnamuck
the amc 20 is not a c-clip axle.
runnamuck
get the kit, it has everything you need.
gschuld
Please forgive my ignorance. I have never taken a passenger car small bolt pattern model 20 apart. My CJ has been running a dana 44 for many years. By "the kit" do you mean what comes with a new set of Moser axles or something extra? I just want to make sure that I have done everything reasonable to prevent an axle from either breaking, spinning a hub, or leaving the alxe housing in dramatic fashion! I've watched a model 20 chuck an axle at Atco raceway once. Not something I would like to experience myself.
Thanks,
George
CJim7
Yep. The Moser kit will have everything you need except probably new backing plates. you will need to reuse the old ones most likely. My Superior kit was this way, no backing plates.
gschuld
Thanks...now I may proceed :?
George
If you want to make it as strong as possible get the full floater kit for it and run drive flanges or hubs on the rear. this will make loosing a tire very difficult and make the shafts last longer.
