Anyone else used the ProForm #66784 Valve Spring Tool successfully on AMC heads ?
Bought one of those ProForm "in the car" Valve Spring Compression Tools
but did a quick "check test", and don't think the ProForm Tool will work
on AMC Heads, but not sure.
Wiped a cam lobe on the new motor. Starting over.
Last time, new double valve springs were on for break-in.
Not real stout springs, Crane BBC Duals #99893-16
~#120 closed & ~#315 open, 1.88 installed, ~.520 lift
"Premium RV/Truck power applications. Flat tappet racing use."
This time guess I'll remove the INNER valve springs
which means they'll need re-installed after break-in.
