AMX69PHATTY wrote
I remember ready all your good cam tech info 82Waggy.
Don't tell me, I'm barking up the wrong tree with this cam?
Well, I don't know that I am any less confused then the rest of you when it comes to choosing a cam - Manufacturers recommendations are all over the map and pretty much less than helpful.
I try to follow some rules of thumb when choosing a cam and then make adjustment until I'm satisfied (adv/rtd adjustments, change cams, etc.).
I can tell you that, in general, if you need to retard a cam past the manufacturers straight up recommendation for intake lobe centerline then you probably have the wrong cam for your application. BUT, don't confuse that with using a timing gear keyway that may be different then the straight up position marked on the timing set in order to achieve the lobe centerline recomendation. Retarding a cam delays intake valve closing point and decreases cylinder pressure, so you start to lose torque at some point faster than the higher rpm can make additional hp - a point of diminshing returns.
I'm looking at this solid tappet cam for my 390 build that will be pushing rpm a bit more than my 401:
Camshaft Engle 5002sld
Intake Rocker Ratio 1.6
Exhaust Rocker Ratio 1.6
ILCL (Crank Degrees) 106
ELCL 110
LSA 108
Int. Duration @ .006 275
Exh. Duration @ .006 275
Int. Duration @ .050 245
Exh. Duration @ .050 245
Intake Lobe Lift 373
Exhaust Lobe Lift 373
Intake Valve Lift 597
Exhaust Valve Lift 597
Tappet Lift .020" .050"
Intake Open, ATDC -32 -17
Intake Close, ABDC 64 49
Exhaust Open, BBDC 68 53
Exhaust Close, BTDC -28 -13
Overlap 59 29
Hydraulic Intensity 30
Recommended RPM's 2000 - 6000
