1980_Cj7
Well, instead of a problem or question, I thought I'd share some good news for a change. She's just about ready to drop back in the Jeep. Maybe even tomorrow evening if the weather cooperates.
AMX69PHATTY
Ground Poundin' 401 :shock:
Just got mine out and partially disassembled today :smile:
Soylent_Green
Nice!
Gives me a warm fuzzy thinking about the sound that things gonna make.
Blown7
Congradulations :t:
Jeff
1980_Cj7
Thanks guys. THE 401 IS BACK IN THE JEEP AND THE EXHAUST IS CONNECTED UP AS OF 8:30 TONITE!
We'll start buttoning up all the cables, hoses, wires, etc. and put the radiator and grille back in tomorrow afternoon. Since it was in before, and everything is was hooked up before, the rest should go back together pretty quickly. All the mods we had to do to go from the 258 to the 401 have already been done.
AMX69PHATTY
wwwhhhhrrrrrrrrrrrr vrooooom
buba - buba - buba - buba - buba - buba - buba - buba
1980_Cj7
All that's left to do tomorrow after work is drop in the distributor and hook up the spark plug wires, fill the radiator, and put the battery back in that's charging as I sleep, then we're ready to turn the key and see what happens.
Geez, turning that key for the first time is a nerve wracking, scary experience!
1980_Cj7
Well we turned the key tonite...and nothing
bad happened! It started right up and purred like a...LION! Broke in the cam again for good measure. All vital signs looked good. Sounds SUPER!!!
Took 'er for a short spin then, but it got dark on us and we didn't want to do too much in the dark. Tomorrow after work, we'll change oil, check all fluids again, then take 'er for real ride . Feels really good to hear her finally running again!
And I finally found something that works on exhaust manifolds...POR Cast Iron Gray high-temperature exhaust paint. First thing I ever tried that didn't burn off right away. Still looks as good as in the pic on the engine stand above.
hugh
That sure looks nice, just out of curiousity, do you remember what type of throttle cable assy you are running, in the picture it looks like a braided stainless steel line. A Cj with a 401, what a hot rod. :t:
1980_Cj7
Thanks for the compliement. My son and I are both very proud of our "joint venture".
Yes, I do remember. It is a Lokar setup that has both the throttle and automatic transmission throttle pressure cables. Got it from Summit. They are braided stainless steel, in fact, everything is stainless. It wasn't cheap, but it is a top notch piece of equipment. And, it adds 23 extra horse power!
PS-the braided stainless cable sheaths are long so you can cut them to the length you need, but can be a PITA to cut.
AMX69PHATTY
Great ! :t:
much better this time I guess ?
no funny spark timimg issues ?
Now the hard part, be easy on it for a few hundred miles,
before ya really wrap on it :shock:
Wheels in the Air ! :!:
1980_Cj7
Nope, no timing issues whatsoever. We set it at TDC and pointed the rotor at No. 1, and it tried to start right away, but wouldn't quite catch. Turned the distributor counter clockwise a hair to give a little advance, and she fired right up. After the 20 minute break in, put the timing light on it and set it at 10 advanced. She cranks real easy now, not that strained barely-able-to-turn-over thing we were experiencing last time around. Seems to be doing better temperature wise this time too, and running much cooler, but we really haven't had it out on the road yet either.
I've heard you should do a few half throttle hard acceleratons to seat the rings. I've also heard not to baby it and to just run the crap out of it from the get go.
All I know is so far so good. We do still have some racing fuel mixed in with the gas currently in the tank from when she was pinging last time around, so we won't really know how the pump gas works til we use that up, which shouldn't take long if it goes thru gas like it did last time it was running.
Now, I just hope it lasts A LOT longer than the 300 miles we got out of the last rebuild!
AMX69PHATTY
That's good to hear.
300 miles aint too bad, I only got 30 :smile:
but I was the one who put it together #-o
This is the first thing found when I went looking
then from there found the bad #4 ex lobe & lifter.
Keep an eye on your rocker adj and lifters for a while and
maybe after awhile, pull the dizzy and check the gear.
:idea:
1980_Cj7
Fuzz, post up a picture of your "pretzel connecting rod", ha, ha. Maybe we could put that and AMX69PGHATTY's pieces together and make some kind of 401 sculpture, ha, ha.
I had forgotten just how loud and vicious our 401 sounds until we terrorized the neighborhood last night on "maiden voyage II". And right at "quiet time", of course. Even had one neighbor come out of their house and stare. It was a different neighbor than the one who read Fuzz and I the riot act when Fuzz came to visit and made some noise. We're becoming more and more popular, ha, ha.
Fuzz was the first one besides us to hear the beast roar last night, long distance, courtesy of "can you hear it now". After all, he had a big part in our successful rebuild. Wish I had a way to make a good recording to share it with all of you here who helped us out. Tried recording on the cell phone, but that really comes out crappy-sounding.
AMX69PHATTY
I try to imagine what it was like way back when in the day
when a whole lotta folks had loud jeeps or cars.
Nowadays they've gotten so quite, a loud one sticks out.
So to keep "reputations", did you terrorize ...... er .... drive
it around the nieghbirhood again yet tonight ???
Gotta hear that buba-buba-buba-buba-buba sound man :wink:
:shock:
fuzz401
1980_Cj7
Well, as high as I was last night, I'm just as disappointed tonite. We changed oil and filter, checked all the fluids, then took her for a ride. We didn't go very far last night, but went about maybe 5 miles tonite.
Well, first off, the temperature is climbing again. It hit about 220, and I think it would have gone higher, but we stopped driving it. It's funny, it will sit and idle all day and not go over 180, but as soon as you take it on the road, it starts to heat up. Same thing is was doing 1st rebuild. Once we stopped driving, we let it sit and idle and the temp came right down. The 2 speed Taurus fan is pulling plenty of air, much more that the stock belt driven fan. It will suck a rag right up against the radiator from about a foot away.
The other thing is it doesn't have much power. Again, about the same as last time around. Hard to believe with all the problems it had last time.
WHAT A BUMMER!!! It sure does sound good though.
CoriolisSTORM
sound clips?
Rhinolined360
It can't be the fan, my fan is really crappy for my 360 and it does the job, is your thermostat opening, there should be like a peak in temperture then a drop you know...
1980_Cj7
Rhinolined360 wroteIt can't be the fan, my fan is really crappy for my 360 and it does the job, is your thermostat opening, there should be like a peak in temperture then a drop you know...
I'm trying to remember what thermostat we have in it. I just looked on the shelf and found a 180, a 195, and an empty box. The empty box doesn't have a temp on it. The two t-stats are Stant's, but the empty box is a CST, made in Israel.
If memory serves me, we started out with the 180, then went to a 160. I just looked up the CST part number and that empty box is from a 160, so I'm betting that's what's in the engine.
I'll have to watch carefully next time we start it up and see if it does momentarily drop back after it initially hits 160. We have a real good Autometer gauges in it so we can monitor it a lot better than with the crappy OEM "cold/warmer/hot/uh-oh" gauge. I'd say the t-stat is opening because I was watching in the radiator the other night on the first start up and at one point I could really see the coolant start to circulate.
Wonder what would happen if we ran it without any thermostat? Fuzz, what temp t-stat are you running?
