pfabricy wroteWhat I'm reading in my Chevy SB engine rebuilding manual is that under the cam bearings is a small groove that allows oil to flow to the lifters. They mention that if there's been a lot of dirt in the engine then they get clogged. The mention that if you round off a lob(which I did) then there's a good chance they are clogged.
I'm not sure what to do other than pull the engine and do a whole rebuild since I have to get the cam bearings out and make sure the passages are clean. :smile:
not the right book to judge a amc by. i think the problem is crappy lifters. there is only like two companies makeing lifters for all engines now, yes all engines, and i have ran into some bad metallergy in replacement lifters at work. same problem as descried but not as bad. other engines oil the bottom end first.
