AMX69PHATTY wroteI took off a cam lobe and wiped out a lifter on my new motor.
<Snip>
Not sure if I'll do this next time or not, sounds messy,
but after wiping out a lobe on a new motor
looking for way to prevent it happening again.
Use molly paste on cam lobes, lifter bottoms, and dizzy drive gears. Put a dab of assy lube like Torco or Royal Purple on pushrod ends and valve tips. Assy lube on all bearings. Motor Oil on timing chain.
Poor a bottle of GM EOS over the installed lifters in the valley and the rocker arms. Use Castrol GTX or Delo 10W30 for break in oil, less 1/2 quart to account for the EOS.
Change oil and filter after 30 minute run-in at 1800rpm and include another bottle of EOS.
Change oil and filter again after 100 miles, less the EOS, to whatever you plan to run normally - I like Mobile 1 10W30.
AND MOST OF ALL, ensure that your block and motor parts are all squeeky clean when assembled.
After initial clean up and machine work is complete;
Solvent brush all oil pasages in block and crank. Soak block with a large can of orange spray cleaner and then head to the nearest car wash. High Pressure Soap wash the block (about 7bucks worth), blasting through all oil passages and bores - do not rinse with water or it will rust quickly. Spray all bores with WD40. Blow dry with air gun all bolt holes, passages, and block. Swab all bores with clean white bar towels and WD40 until no black appears on towels.
Wash crank and cam in soapy hot water - blow dry. Buff crank journals with a clean bar towel.
Clean all other internal engine parts, both new and old.
Wipe off new bearings with a clean bar towel (I like to spray clean with Ether and then wipe).
Put engine together and keep it covered/bagged until ready to install.
