jeepsr4ever wroteI have had this problem in the past. What I have done was use a propane torch and get the gear warm (Just too hot to touch) then the gear slides right off and you didnt heat it up enough to distort or anneal the gear.
I thought about doing that. When I first hooked the puller up, it didn't seem like it was going to move. I was debating what to try next, but I put the puller back on and tried again. All of the sudden there was a cracking sound and the gear broke loose. It came off pretty easily from that point. It is a TIGHT fit. I was hoping and praying that I repositioned the gears right so I wouldn't have to pull it a second time. Luckily they were right on the first try.
Thanks MC for the quick delivery on the crank turning nut by the way. It was invaluable in degeeing the cam. It also came in very handy for tapping that tight RollMaster timing gear back on the crank.
