Ok, Here's the violations MY truck is guilty of....
absence of tire information placard installed by the original equipment manufacturer
mud flaps do not extend across the full width of oversize replacement tire/wheel assembly;
aftermarket fender flares do not extend beyond the full width of oversize replacement tire/wheel assembly;
loaded static tire diameter of an oversize replacement tire/wheel assembly exceeds 34 inches (864 mm) when measured horizontally at the wheel hub.
fuel tank from aftermarket modifications or a change in original location makes it more exposed and susceptible to being punctured in a crash;
shock absorbers are leaking oil or could be damaged by the full extension of the suspension travel; (I need new shocks, but can't tell because the springs are so stiff anyway)
bump stops were removed or mounted at a different location than originally intended;
Ummmmm. That's is for this particular law.....
