The 74 has swinging pedals,doesn't it? (mounted under the dash rather than coming up thru the floor).
As long as you have swinging pedals, a master cylinder and bracketry from a 76-86 CJ should be adaptable. The power booster uses a bracket that spaces it out away from the firewall. I've heard the early (pre '74 ?) Wagoneers are the same also.
For top of the line stuff go to www.mpbrakes.com
