E10 and E20 (10% or 20% alcohol) ethanol blends will work OK in most gas engines. Older engines (pre 198?) that have rubber seals in the carbs may have a problem, since the ethanol will attack the rubber.
I wouldn't run E85 (85% alcohol) in anything but a modern fuel injected engine that is designed to run it. A carbed engine will need some jetting and timing changes, plus a check or change of the above mentioned seals. The high alcohol content will also have a detergent effect, and loosen any gum and varnish in the tank and lines, so be prepared for clogged filters and jets.
just my $.02
