OK
Well, I finally got lucky and figured it out!!!!
I install a rod behind the cap for the plunger spring to hold to plunger closed, started it up and the oil psi jumped past 80 (80 max Steward Warner gauge) at idle and blow the gasket out, what a mess.
I had another oil pump kit, a Clevite #601-1260 so I put that in in-place of the new Melling kit I was using.
WaaaLaaa!!!!! Oil pressure at idle steady 45psi, and 70psi at 3000rpm. I measured out the plunger and the spring on both kits before installing the Clevite kit and they where the same, the spring must have been the difference, I couldn’t tell from squeezing them if one was stronger than the other.
The added volume at higher rpm must have been opening the plunger and dropping the psi.
I want to thank everyone for the advice and info, hope this helps someone else down the road.
I know it was driving me madd, just ask the wife!!!!
Go figure, I fixed it on mothers day.
:t:
