BREK
"New" jeep axle assemblies
Now available from mopar performance- Jeep wrngler rubicon front and rear axle assemblies. The axles are shipped with the current rubicon suspension mounting brackets installed. They are completely assembled, with a 4.10 gear, disc brakes, and locking diff with lock sensor. A limited slip rear is also available. Adaption of these units is the responsability of the purchaser.
Specifications
Axle ratio: 4.10
Track width: 61.9"
Wheel bolt pattern: 5 on 5.0"
rear axle tube diameter: 80mm
Front tube diameter: 63.5mm
Front brake rotor: 302mm diameter x 28mm wide vented
Rear brake rotor: 316mm diameter x 12mm wide solid
Pricing/ordering information
p5153825 front axle assembly, locking diff $1,479
p5153826 rear axle assembly, locking diff $1,349
p5153827 rear axle assembly limited slip $1,099
I took a look and these are already on backorder. Chrysler doesen't show at this time if,and,or when they plan on shipping any out.
