JERSEYJOE COULD SOMEONE TELL ME WHICH ALTERNATOR THIS BRACKET IS DESIGNED FOR. THE STANDARD DELCO DOES NOT SEEM TO WORK. I WANT TO USE ONE OF THE LATE MODEL GM HIGH OUTPUT ONES, BUT BEFORE I BUY IT I WANTED TO KNOW IF IT WOULD WORK. THANKS
JERSEYJOE the standard Delco alternator has a smaller diameter hole. I did not want to use standard Delco, I wanted to use one of the high out put ones. A diagram might help. It's obvious where the top mount goes, on the intake and I assume this is for the thick part of the alternator, the curved barcket bolts where???? I was hoping that someone had used this before and could send a photo and a recommendation for an alternator. By the way the alum pulleys are slick. A couple of locals stopped by and were impressed. They look great next to my Jet Hot shorty Headers. And the pilot bearing fit like a glove.
1tuffcj hey joe i can't see the picture, i'm useing a hi output alt 140 amp. show me the pic maybe i could help, i had some problems with my bracketry. mikey. p.s hows the intake working out for you, did you use it yet?
JERSEYJOE Yes your intake is the one I am using. If you have this bracket could you shoot me a picture of it mounted. Exactly which alternator are you using? Thanks Mikey!!!!!!!!!! send pic: [email]jbelfiore@mercuryinsurance.com[/email]
Lifted79CJ7 I have a 115amp (custom wound from all new parts) alternator for sale if you are interested. I used if for around 3k miles, then it has been sitting for the last 3 years. Let me know if you are interested! Jack [email]lifted79cj7@aol.com[/email]
1tuffcj JERSEYJOE wroteCOULD SOMEONE TELL ME WHICH ALTERNATOR THIS BRACKET IS DESIGNED FOR. THE STANDARD DELCO DOES NOT SEEM TO WORK. I WANT TO USE ONE OF THE LATE MODEL GM HIGH OUTPUT ONES, BUT BEFORE I BUY IT I WANTED TO KNOW IF IT WOULD WORK. THANKS sorry joe i just read the post again, i should of read the subject better. i don't have a (bulltear alt bracket), in your post i just thaught the picture did'nt come up on my screen, when you said (THIS BRACKET IS DESIGNED FOR). my bad!!!!!! #-o
jdubya I'm installing a CS144 on a AMC 360 using the Bull Tear Alternator Bracket. I got the main bracket on with no problem: However the bottom isn't even close to lining up: Has anyone done this install? Can anyone lend any advice?
JERSEYJOE Thanks man that's what I wanted to see. I ran into the same \problem and I just wanted to know if it was me. what kind of alternator are you using?
