Shit, I forgot the other formulas in my room... I'll repost later with the formulas for milling the heads for desired CC & CR...
I do have at the moment...
Gear Ratio = RPM x TIRE DIAMETER / MPH x 336
EFFECTIVE DRIVE RATIO
Effective Ratio = Old Tire Dia / New Tire Dia x Original Ratio
EQUIVALENT DRIVE RATIO
Equivalent Ratio = New Tire Dia / Old Tire Dia x Original Ratio
Alright here is the formula etc....
AMOUNT TO MILL = New Disp. Ratio Minus Old Disp. Ratio Divided by New Disp. Ratio Multiply Old Disp. Ratio...... Once you get that number Mulitply that by the Stroke.
If you know your current specs then you should be able to apply this very easily to your heads etc.. You could also "0" deck the block etc...
NDR - ODR
NDP x ODR
Then x by the stroke
