BREK
Does anyone know if prothane part # 7-1604 for jeep applications will work on my amx with a t-10?
I think that's the one I have under my Jeep. If you have some measurements, I can see if they match up.
BREK
I'll get some measurements tonite
BREK
on the crossmember side of the mount there are 4 bolt holes, length from center of bolt to center of bolt is 3 1/4" overall length is 3 15/16", width between bolts is 1 1/2" and overall is 2 9/16". on the trans side lenght between bolt holes is 3 1/16", and overall is 3 15/16". overall height of the mount is 3", part # stamped on mount is 3183856. This mount does have the mounting "ears" on the trans side not studs. I also have pics I could e-mail if that would help.
Thanks
Brek
That is the one under my Jeep, but it's a GM style. Just a square block with a metal plate top and bottom. The top has 2 slotted holes for bolts that thread into the trans, the bottom has 2 threaded holes for bolts (or studs) that go thru the cross member or skid pan.
If your T-10 uses one anything like the mount under my BW M12, it's nowhere near close.
BREK
Yeah sounds likt I will just have to use the rubber one I ordered from americn pats depot.
Thanks
Brek
