Wow... sounds like fun.... I didn't feel like spending the money for the HD output shaft so I made my own Shaft (Bigger than AA and I made the Housing out of SS).. 8)
The only thing that you have to worry about now is splitting the case in-half... no joke!.. The weakest part on my Jeep is the driveshaft... it's easier to replace/make a driveshaft and it's a LOT cheaper... Junk yard specials...cut, machine, and weld... keep run-out to a minimum and you'll be straight :wink: then if you wanted you could have it balanced......
