CJim7
I had what i thought was excessive lifter tap until i pulled a valve cover and discovered my rockers, pivots, and pushrods were in desperate need of replaceing. Some were extremelly worn, but the worst of them was on the exhaust side of each cylinder. On most of them, the oil grooves on the pivots were completely gone and the pushrods were missing quite a bit of material at the top end. The intake assemblies didnt look near as bad.
Question is, what caused this? A timing issue where the exhaust valve is trying to open late on the upstroke of the piston...and is therfore under more pressure then normal causeing excessive wear on that particular set of components?
.....Or is it just normal for the exhaust side to wear more then the intake side :-| (i really dont buy that)
on the upside, after replaceing the entire set of rockers and pushrods, the engine runs baby-smooth...no more lifter tap.
