jeepsr4ever wroteTF trannies are VERY sensitive to kickdown. If you run without it you can burn one up in a day. Holley may suggest this because of the way the throttle adapts to the body of the carb. It may not have a second spot for a kickdown so they made their claim. Like you said you are running a Lokar so you should be fine.
Thanks. I was hopeing to hear that. Now...as long as I have it adjusted properly.....
Any sugestions?
The carb does in fact have a kickdown. Which is funny cause it says to not use on a auto, but yet talks about using one in the directions.
