Thanks for the chain brand ideas...I will check around.
I have a NP205 for the truck...but I have to change the tail shaft out of the TH400 and switch input gears on the NP205 for the TH400 because it is for a TH350. That is the set-up I will run for the truck pulls. But $ limit me to wait until maybe next year for the NP205 install.
That being said a new chain and another low range unit would be needed. I smoked my only low range unit at the first pull I used it at.
The plate that drops into the back broke and spun in the case. I assume that it just had to much torque and/or weight that I was pulling. I also assume that another unit would do the same at a truck pull. Pulling RPM will be around 5500RPM in 1st gear...maybe that is too much RPM for the unit also?
any thoughts?
I think the transfer case with a new chain will hold for a few pulls...but the low range unit is the weak link I believe.
Does anyone now a way to beef them up? Maybe they just won't handle a truck pull?
It's kinda embarrassing to be pulled off the track when the truck doesn't move. :oops:
