AMX69PHATTY wroteIs that the Clevite CAM 1980_CJ7 used in his 401 build
that hosed the pistons because the builder incorrectly installed
the cam gear on the oil passage instead of the keyway ?
The intake closing angle is early and increases dynamic CR ?
At .006 tappet lift and 105 degrees intake lobe centerline:
Engle35018 Intake closes @ 49deg ABDC,
Clevite #1 Intake closes @ 61deg ABDC.
I think 1980_CJ7 was using clevite #2, which has an even later intake closing point.
Yes, the earlier the intake closing point, the higher the dynamic cr.
Be sure to match up intake lobe centerlines when comparing valve timing.
PS: BTW there is still plenty of flow through the valves at low rpm at less than .050 lift to lower dynamic CR. When considering bottom end performance (torque) I always look at the .006 figure, and use the .050 figure to get a feel for high rpm performance. The less duration at .006 with the most duration at .050 gets you closer to the best of both worlds (Called "Hydraulic Intensity" by Harvey Crane). The abilty to lower this difference is one of the great advantages of the AMC engine with its' large diameter lifters. Unfortunately, many flat tappet cams are just Cheby grinds in AMC clothing.
